The Cool Thing About the Selepeed
2.6K views 24 replies 9 participants last post by  Trailbraker
#1 ·
I know a lot of you already know this but I didn't so I've done a little research on the selespeed gearbox to find out what it does, as I've heard a lot of good and negative. Well Im pleased to say that what I found out made me feel better. Its derived directly from the Ferrari F1 gearbox, it does have a real clutch controlled by hydraulics, not a talk
Converter like tiptronic auto gearboxes. But the coolest thing I found out was that it has a sports mode that gets gearchanges down to .7 of a second.
All you need to do is change gears at over 5000rpm with the throttle at over 60%. Its fast. So in short Im not to worried about my choice of selespeed over manual.
#25 ·
You need to read the smallprint as to how shift times are measured.
It should be from intial torque release to return of full application of torque.
The 147 GTA selespeed does this in 0.4s as I remember from some earlier thread I participated in on this.
Some other MArques brochures will say responds within 100ms but they don't mention that they might actually be finished for quite some time :)
I'm sure there are in fact quicker systems around now than the Selespeed inluding many of those on the list, and the impressive DSG sounds like best option to me.
#20 ·
You also need to checkout to comparative costs to have those gearboxes when they are an option.
As for the ultra-quick BMW SMG II gearchange, that comes with a warning that you will break the gearbox if you keep it set to the fastest speed...
#18 ·
can i just add that whilst 0.7s is a very quick change, the DB9 does it in 0.25s
here, to make us all feel slow...
Here lists the minimum shift time of the most popular automated manual gearbox:
Gearbox (car)
Min. shift time
BMW SMG II (M3 E46)
80 ms
Ferrari F1 (Maserati 4200GT)
80 ms
Ferrari F1 (360 F1)
150 ms
Ferrari F1 (Enzo)
150 ms
Bugatti Veyron (proposed)
200 ms
Ferrari F1 (575M)
220 ms
BMW SMG (M3 E36)
220 ms
Aston Martin Vanquish
250 ms
BMW SSG (3-series)
250ms (150ms for 1st to 2nd)
Alfa Selespeed (156 Selespeed) (old)
700 ms
were the slowest out!
the selespeed is a great system in my opinion, although it doesnt seem to like revving much past 7k... makes some weird and wonderful noises changing gear at 8k rpm lmao
bit background... CLICKY CLICKY
#17 ·
Re: The Cool Thing About the Selespeed
cj romeo said:
The Vanquish I didn't mention as it gets possibly the worst press of the lot for these systems.
Aston have taken a very different philosophy with their 1st gear ratio, everyone else fits a very low 1st gear ratio to ease the load on the clutch (1st is the same as reverse on a Selespeed), Aston chose to fit a 1st gear which is good for about 60mph... The result is a lot of clutch slip when manoeuvring. Apparently there is a passage in the manual warning that the smell of burning clutch is to be expected when trying to park!
#15 ·
And the Aston Martin Vanquish.
BMW use two completely different paddle-shift systems.
The "M" cars use a Siemens developed system, all the others get the Magnetti Marreli system.
#12 ·
The system on Fiat, Alfa Romeo, Ferrari, Mercedes, Maserati, BMW, Renault and Peugeot-Citroen are all basically the same and are manufactured and patented by Magneti Marelli.
They all have lineage that can be traced back to Ferrari in F1 in 1986 which was the first application of Selespeed. Basically it can be engineered onto any manual gearbox.
The new Lexus supercar will be fitted with Marelli actuators and CAN BUS interfaces, so that will be the end of their reputation then!:lol:
#10 ·
Rob 156 said:
Surprised it is ferrari derived, I thought it had some robot thingys controlling the normal gearbox and clutch.
And what do you think the Ferrari gearboxes have?
My understning was that it was a development of the system used in the Ferrari 355 F1 road car, which itself was a development of the system used in the F1 race car during the time Mansell & Prost were at Ferrari.
The system was then further enhanced in the 360 F1 road car and that is probably close to that used in the 156/147GTA.
