Hi I am after any advice please! I've lost all faith in my car ?.I've been without my gullietta for 6months now, due to being in the garage and no one can fix the issue! Check engine code and limp mode comes on I have to pull over and restart car to get rid of the limp mode but will come back after 3miles it is coming back as Maf related but I've had dpf/maf/egr/turbo boost sensor/oil filter/air box/oxygen sensor/all pipes/tubes/apparently turbo has been checked too all have been checked and replaced if needed and still goes into limp mode. I've had 2 auto electrician look at it and said it was maf so had that changed for the second time but still the problem is still happening with same code (maf related).
Does anyone have a clue what it could be or had the same issue? Any advice would be much appreciated. Thank you
