Drivers door does not open from inside
1.3K views 11 replies 5 participants last post by  wbanham
#1 ·
I know this problem has been raised here but the search was not successful.
I can only open the door from the inside of the vehicle by lowering the window and opening with outside door handle.
Help!
#8 ·
The unlock button does not release the drivers door but does release passenger door. Handle is good and it feels like the cable is the same as it was. I did see a post here some time ago of a member who was locked in his car but I have been unsuccessful with the searches. I am almost certain that he resolved it by adjusting settings on the dashboard
#9 · (Edited)
Open the door and using a screwdriver or metal bar to move the lever in the U shaped part of the lock to simulate the door being closed. Now try releasing using the interior handle. Does that work? If it does it may be that adjustment of the part on the door frame is required. If it doesn’t release the problem is within the door; the door trim is easily removed and there are guides on YouTube. It may be the lock itself. I’ll see if there are replacements available.
Image is of the general arrangement; it’s actually a rear.
