2,5 TB/DS (CEE-F2) Supers came with duals with A/C BUT not all, w/o A/C came with single fan. But no V6 supers.
V6 Super only came with a single fan.
No 164 except for the Q4, 2,5 TB/DS (CEE-F2) A/C version came with a Dual fan (155 shared the same fan as the later Q4).
You may be confusing the automatic transmission smaller fan.
I guarantee it did not come with a dual fan if a V6 (which I am assuming it may be?), unless previous owner installed a Q4 an.
Dual fan set up on Q4 is two equal size fans that cross the radiator only.
This is the dual fan for the Q4, f you have this on your Super it is an after thought as they did not come with dual fans or you have a 2,5 TB/DS (CEE-F2) which was not detailed in this post.
*Early Q4's as well only came with single fan (which I assume you have as well) only Fl Q4 came with dual:
http://image1.frappr.com/pix1/i/20080630/4/f/e/4fec5b8d63b3597e472ab7f433e417d00_large.jpg
