Turn signal indicator relay location
22K views 12 replies 7 participants last post by  Sofiane_N
#1 ·
Does anyone know which is the turn signal indicator relay? I tried removing every one of the relays in the fuse box area in turn, and the indicators still worked every time. :confused:
I want to know because I'd like to replace the incandescent indicator bulbs with LEDs, and so will need a new LED-compatible relay.
#2 · (Edited)
The workshop manual says relay N13, next to the main fuse box. It also says it has a black base. There doesn't appear to be a variation for LHD or RHD.
#3 ·
On RHD versions it's in the fuse box underneath the steering wheel where your right knee would be, one big relay does both sides and the hazards too. Turn them on then touch the top of each relay in turn, you'll feel it clicking in and out, assuming that it's working in the first place. LOL
#4 ·
Took a while but found the relay, the ticking was a helpful hint.
Anyone know a good place to get a replacement relay? (my right indicator doesn't work but bulbs and hazards, left indicator fine). It's a Saturday evening so can't check if the Alfa dealer stocks them, will give Autolusso a call on Monday.
#7 ·
Melb,
According to the workshop manual, on RH drive cars, the N13 (Hazard Warning Light & Direction Indicator Intermittent Device) lives on the ancillary rail that is located above the main fusebox. The N13 should live on a BLACK base. There are 2 more items the live on black bases, that are on the rail, they are the Fog Lamp Relay (20A) and Engine Cooling Fan Relay - 2nd speed (50A).
PM sent
#9 · (Edited)
Found it!!!!!!!:thumbs::thumbs: It lives behind the speedo assy, you can access the relay removing the fusebox access panel and look up. Have sent another email with picture.
#11 ·
Hello, i also have a problem with that relay since the past owner of my Spider V6 1996, removed it to change it and he didn't do it and lost the relay :cry:
So I have to buy one and I don't know how it looks like and I also have to replace it and I can't locate his place ! Can you help me please.
By the way, the AC also stopped, I don't know if its an electric problem also.
