TCT gearbox problems and codes
17K views 10 replies 5 participants last post by  Rambo1664
#1 ·
Hi
I have a 2014 jdtm Giulietta with a TCT gearbox. Yesterday while driving normally the start/stop cut out followed by the engine management light coming on with the car being stuck in 2nd gear (no reverse gear etc.).
Called the AA and they diagnosed the following codes:
P0805 clutch position sensor short to ground
and
P0700 transmission control system invalid date from node.
Has anyone else had the joy of these two errors before I start ringing around gearbox specialists?
#6 ·
I only ask because I've had problems with my TCT although I never looked at codes, mine used to get stuck in 2nd with no reverse so I'd stop, turn it off. Lock it, wait a minute then unlock and start it, sometimes I had to do this more than once to get it going then it would be fine.
I also could feel the difference in the gear changes so every now and then I'd charge it over night and everytime it sorted it out.
Of course overtime it got worse and had it tested at a battery place down the road and they told me it was fine so I assumed I had real gearbox issues.
I took it to an Alfa specialist and he put his snap on tester on the battery and it came up replace.
I have replaced it and I haven't had an issue since.
#7 ·
That makes me feel a lot more optimistic! Luckily I know a good independent Alfa specialist nearby who I’ll ring in the morning and suggest this to him before approaching gearbox repair specialists as this does seem a promising idea.
I’ll update the post when I know more but fingers crossed 🍀
#9 ·
lol aren't they just. Gearbox faults mainly including stuck in 2nd, no engagement at all and badly timed changes.
Mine had the Halfords advanced 096AGM battery on it when I bought the car, it looked brand new when I bought the car in Jan 2018. I've replaced it with the slightly cheaper Halfords EFB096 and its spot on.
