The cable on my 86 Spider Veloce power window regulator broke right where it runs through the winder drum. Replacement regulators complete with motor are available but I like to repair the cheapest way possible and don't really need a new motor. After determining that 1/16" cable, available from most local hardware stores was about the same as OEM cable, I carefully removed the old cable and replaced it with new cable, swedging the ends where they go through the winder drum per original using commercially available cable stops. Unfortunately, I am stuck because I don't know how to properly route the cable and how to take up the slack for proper tension. I could remove my door panel with the good mechanism and duplicate it but hate to disturb that trim panel. I have a repro shop manual from IAP but the detailed window regulator diagram is for a manual regulator and the power regulator diagram doesn't adequately show the routing of the cable or give many hints how to reinstall the regulator. My problem now is figuring out the routing of the new cable. The IAP shop manual diagram appears to have an extra cable run pictured than is not possible with the pulleys available on my 86 (2 upper front & rear & 2 lower at each end of the bottom window track). Then too there is the problem of getting the cable rewound onto the spool so the cable has the proper tension and will not spool off the winder spool when it turns. I'd appreciate it if anyone has a detailed diagram of a Spider power window regulator installation showing all the pulleys and pivot/attachment points and has any tips on how to get the cable rewound and tensioned properly.
