puddle lights
Tags
puddle
2.9K views 6 replies 4 participants last post by  gingerjon9
#1 ·
hello there,
the puddle light in the drivers side door of my 147 is not working, the bulb is good so I guess it must be a fuse, got my manual out and cant find puddle light fuse anywhere, does anyone know which fuse it is and where it is located?
thanks
#3 ·
Can you not pull fuses till the puddle light on the other door goes out, see what else that fuse does.
Good luck
Pub
#4 ·
I doubt it's the fuse. From memory the puddle lights are on the same fuse as the climate control and radio so if these are still working it's probably a wiring issue. Maybe try checking the connection in the multi plug situated in the door jamb
