Here's some info on what's going on with my sprint right now...
As you may or may now know, I bought a 1986 model Alfa Romeo Sprint 1.5 QV in january of 2004 ...
The Sprint served me for about 2 weeks in active duty taking me from home to work and back while my previous 33 was waiting for new shock absorbers...
After that it was driven about 100 km north east from my home into a yard of a american car club... There it has been waiting for almost a year now!
In the summer of 2004 I gave it it's last run (well I had it idling for 10 minutes) as for some reason, no gears would go in
After that I removed both of the carburators, to take them back home for cleaning... I cleaned the other carb. right away, but came across some troubles... one of the adjustment screws (do not know it's name right now
) was (and is) jammed, and while I was trying to remove it, the groove in the top was damaged, so it can no longer be adjusted, nor removed... I'm thinking of drilling a new groove at the screw to get it out, and hopefully the repair kit i'm going to buy will have that screw!
I have considered new carbs. as they cost "only" 170 € per piece
No further job has been done to the carbs...
I have also removed the backseat and some of the backseats side panels and door panels from the Sprint. The back seat has been cleaned well and it is in good condition. The front door panels have had aftermarket speakers installed so there's a BIG hole in both sides. I'll be making whole new panels to them as soon as I get some material... I'm still thinking what textile should I use for the upholstery... as the backseats sides are leather look alike, I was thinking of making the front door panels leather also
I have also removed the whole meter cluster (nothing wrong with it as far as I can tell) and I also removed the center panel witch has the 5 buttons in it... 2 of the buttons were not working so the previous owner was nice enough to bunch holes in the panel and add 2 buttons of his own!
These buttons were removed by me, and the holes are currently beign covered (look at pics below)...
One of the two buttons that were not working is working now. it was not working because the connectors were covered with thick layer of this nice "green stuff "
The other one of the broken buttons misses a small metal clip that holds the button in "on" position when pushed... Must find a new button to replace...
Well... this is all for now... I'll give an update ... probably next year
