Key Slot Problem and Error U1602
1 reading
17K views 15 replies 5 participants last post by  159pp159
#1 ·
Hello Everyone
I have an Alfa 159 2.0 JTDM and today I observed a strange problem. After shutting down the car and removing the car from the key slot, I have noticed that the red light in the Key Slot never turns off and I keep earning noises from the dashboard. I also notice that the key slot light turns off after 1min but comes back again and the noises start again. I also got one time the error U1602 and the odometer keeps blinking. The last problem I solved by disconnect and connecting back the battery and clearing the code but I am wondering if the key slot problem could be somehow related.
Any Ideas? Is it easy to change the key slot? The car starts normally and I dont get any error when plugging the key in the slot. Looks like the car is trying to shutdown the key slot but can never do it.
Thanks a lot for any help!!
Joao
#3 ·
The odometer is flashing to indicate a 'CanBus' error. When the car is first started the circuits are all tested to ensure that the 'computer' that carries signals to the various devices is within tolerance. The way it signals a failed check is the flashing odometer.
The light on the Fob Slot is normal and indicates it is ready to accept the key. It stays live for a while after shutting down. But then the system enters a sleeping state to preserve the battery and the noise and lights stop.
#4 ·
That is exactly my problem. The light keeps blinking. Today I left the car 8 hours turned off and when I came I could still see it from the window. The odometer flashing i was able to recover by disconnecting the battery.
Looks like my car cannot go to sleep mode for some reason. I tried a proxy alignment but did not help.
Any other ideas?
#5 ·
Just ordered an used TEG reader. My mechanic suspects that there is some problem with it that prevents the car to fully go into sleep mode. I guess i need to do a proxy alignment after installing the new TEG. This problem is being quite anoying :(:( the car is consuming almost 1A after turning it off. Any ideas would be very welcome.
#7 ·
Today I conducted more experiments while the TEG reader does not arrive and I think the problem might something more general:
- I removed the fuse F32 which is "Driver’s door branch point/passenger’s door branch point/ignition device ". Of course with this the light is turned off, but I still hear the noise from climate control which indicates the car is not yet in sleep mode.
- Removed F39 (Supply + battery for air conditioner, ceiling lights, volumetric alarm,EOBD system diagnostic socket) and connect back F32. Now I see again the light from the TEG reader but the noise from the climate control is gone.
with that looks like the problem is more general. Then in a desperate try, I removed F31 which is the body computer. Still the light on TEG reader and Climate Controler Noise was still there. That was puzzling, I was expecting the light to turn off as the body computer controls that CAN as far as I know
I will try to re-charge my battery as I dont have more ideas right now.... just to be sure it is not a battery issue..........:bored::bored::bored:
#12 ·
Today I went to a Alfa Dealer but they said they need more time to find the problem. It is the first they saw this issue. However, I was analying again eLearn and if there were would be a bad grounding on the points C015 and C020, could that explaing the problem? Does anyone every seen those ground points? From the picture I cannot see it very clearly.
All replies would be very very welcome
I am really suspecting about those grounds. it is the only thing apart from the CAN bus I can see it is common to all modules where I see problems.
Images attached
