Inevitable I suppose on a 14yr old car with 165k. I was removing a broken spring when I spotted this lurking behind the rear arch liner. It's all surface rust which extends behind the fuel pipe, onto the chassis leg and beyond. To be frank this is the first time in 10yrs of ownership that I've removed the arch liner and the car did do it's first 90k/3 years in the Highlands of Scotland. The plan is to just treat it, slap some waxoyl on top and hopefully forget about it. Probably should check the other side. The spring carrier was a bit crusty as well, but again just surface rust.
