Giulia battery charge and errors
16K views 87 replies 16 participants last post by  mikheilgtg
#1 ·
Hi all,
I am hoping someone can advise. I got my Giulia 2.2 TD 180 Speciale 17/2017 about 2 years ago and absolutely love it.
From when I got it the Start\Stop and the rear window heaters haven't worked, which I can live with. I also, every now and then, was getting errors on the dash. I searched at the time and it was probably due to a low battery voltage. I have had the battery checked by 2 engineers and they have said the battery isn't the issue. The latest was a battery health check at Halfords, they said the battery was at 80% charge but it is healthy and is probably the alternator. They said not to buy a new battery.
Another engineer said it wasn't the battery and was probably a computer issue and it could be costly to fix.
However I have been getting lots of error messages on the dash, it used to be every now and then, but now it is more regular. Symptoms are, I get the engine light, ABS, start stop errors etc randomly then they go away. I did some reading on this and it looks to be a battery voltage issue, so I am not sure where to look on this one.
I also had an issue a while back where water was coming in at the footwell and it had to do with the aircon. I read this can damage the BCM at the footwell of the car and I am wondering if this is the cause of the issue.
So I have 2 questions;
1. Why is my battery not charging 100%?
2. Why am I getting the errors on the dash?
Any advice is welcome.
Regards
Kevin
#6 ·
doesn't need any coding, just a reset after installing the new battery.
After battery replacement you will probably get christmass tree of lights on dash. To reset, described in the manual, but basic procedure is
switch on
turn steering fully left, hold approx 1 second
turn steering fully right, hold approx 1 sec
turn steeringwheel to centre, hold approx 1 sec
whole procedure should be finished within 30 seconds
repeat if necessary
#7 ·
Regards
Kevin
1. The Giulia's 'intelligent' charging logic is designed to maintain the battery at an 80% State of Charge as measured by the Body Control Module (BCM). So your 80% reading is not necessarily a concern.
2. Nevertheless, the symptoms you are experiencing can often be caused by a failing battery. They might also be caused by a bad earth connection somewhere. Hopefully, not due to a faulty BCM due to water ingress.
My February 2017 Quadrifoglio was running happily on its original battery when I parted with it in August.
The simple solution is to fit a new battery and keep fingers crossed that the errors don't recur, but you might find the battery is not the cause and money will have been wasted. If changing the battery I'd recommend a 95AHr AGM one. It is slightly longer, but there a second fixing hole covered by tape.
Examination of the BCM for signs of water ingress might be a wise precaution.
#8 ·
Don’t fix the stop start, extra wear on the ring gear and, you will be doing effective cold starts if you stop for more than 45 seconds to a minute, on my MX5 I found a way to permanently disable it by removing a switch from the bonnet catch, maybe the same on your car. Mine wasn’t working most of the time anyway, then once in a while I would ‘stall‘ at the lights, then I realised it was working! Anyway I agree with others about the battery causing the stop start issue here.
The HRW can be checked by doing a continuity check with a multimeter on ‘diode mode’ so it beeps when you get continuity.
#10 ·
I have the Stuff4Cars gadget to permanently disable stop/start. Which I strongly recommend.
It is likely that my first Quadrifoglio's battery lasted 6+years because I always disabled S/S.
As far as the HRW is concerned, the BCM prevents the HRW working if it believes the battery SoC is below ~60%. An open circuit is not likely.
owns 2023 Alfa Romeo Giulia Quadrifoglio
#13 ·
I have a stelvio Quad and my stop/start, rear demister and heated wing mirrors didn't work. Had original AR varta battery on it, it's a 2019. Reading Stelvio and Giulia forums took a punt on a new AGM 95 019 batt, easy to fit, found a YouTube vid and sorted within 15 mins . Had all the errors when 1st turned on but went for a small drive, turned off and on all sorted. Only issue I had was the eml was on, this went off after a longer drive and the psi on all 4 tyres had sorted themselves.....
Hope this helps
#14 ·
my stop/ start warning symbol came on about 2 weeks ago and despite trickle charging the battery for 8 hours it's still showing and the HR Window did work okay for a few days, i get warnings about about lots of things like dirty windscreen and main beam etc but I ignore them as they do disappear, it's a Alfa design fault but my previous Alfa GT had zero electrical problems for the 8 years i owned it..beautiful car..
#15 ·
Update on this++
I put a new battery in it in October. I haven't had any warnings since, so it looks like the battery was the issue.
The start/stop still isn't working and the rear heated window isn't working either. I don't care about the start/stop but not having the rear heated window is a pain, especially with the snow and ice.
#16 ·
Most likely explanation of hrw not working is that the BCM is assessing the battery's state of charge as below 60%.
If you had multiecuscan, you could confirm if this is the cause.
What mileage do you do in a typical week?
#18 ·
So I spoke too soon on this. Car was driving fine until I tried to drive to the shops today. The car wouldn't start and I got all the alerts on the screen as well as a "low battery". (Check transmission, esc fault etc) I am putting it on a charge now overnight and I am hoping that fixes it, but now I am totally worried this is going happen again when I need it most. I drove it 3 days ago and it was fine, so I'm not sure how the battery is flat.
Has anyone else experienced a flat battery like this?
I love this car, without a doubt my favourite car I have own. I thought I had fixed all these errors, but if the car isn't reliable enough to start for me I might have to get rid of it. The wife wanted to sell it because we had an issue with the Aircon, but now I don't have an argument if the car isn't starting.
#20 ·
I have experienced this as well. Twice for me. I would have started using a trickle charger overnight but unfortunately I didn't have access to power where the car is parked. I bought a couple of solar panels and a solar charge controller to act as a trickle charger during the day. Whilst it didn't cure the low state of charge (so the hrw and s/s still didn't work), the car never let me down again.
Eventually I fixed the battery drain problem by replacing the IBS (intelligent battery sensor) on the battery negative terminal. Now the car operates exactly as designed, HRW and S/S et al.
#19 ·
Many Giulia owners have had battery issues. Fortunately, only once in 7 years in my case.
There are numerous posts on the subject.
The most likely explanation is that there is some drain on the battery when the car is idle. There are posts giving possible causes.
You might benefit from getting a BM2 battery monitor.
#21 ·
So I tried the charge overnight and it didn't work, still loads of errors. I tried a jump and it didn't work, so therefore it couldn't be the battery. I called the AA and they came out. There were loads of "Unable to communicate to ECU" errors on all the components. My heart sank as I thought I needed a new ECU and my experience with the AA has not been great\succesful.
The engineer tested all the fuses and then started fiddling with the wiring loom. He found 3 broken cables in the main loom, they had worn away rubbing up against the air filter enclosure.
The engineer stripped it apart and soldered them together to get me going. Hats off to the guy he went the extra mile. He said he knew his guys probably wouldn't have attempted it and towed it to the dealer, but he wanted to help me out. He loved the car as well and said it was his first time dealing with one, so I think that helped me.
Very happy now, as I suspect the wiring has probably been causing me other issues and I didn't know it.
#24 ·
I wouldn't panic. I honestly agree with @Andy Bowden that most of the time this can be due to the battery monitor going south although leakage and crap batteries can also be to blame. You'll be needing one of these.. it fixed it on my last car and I'm about to do surgery on this one. FIAT ALFA ROMEO 50548044 CONTROL UNIT
My actual view is that mostly the issue is down to unwanted drain on the battery. Some have found that a faulty IBS is the cause. I believe few are in that category.
  • Like
Reactions: Hurri and jwq
#25 ·
For what it's worth my current car seems to have a fine battery, no probs with leakage, the rear heated screen works nicely BUT start stop doesn't work. Although I have the electronics to turn off the stop start from my last car, they are not installed (it did work briefly at the beginning of my ownership), it seems to have settled in to a way of working that I am good with, I will take the car down to get my battery specialists to test it, not sure whether MES will give me a true idea of it's state.
#26 ·
Your stop/start issue is almost certainly because the BCM is assessing the battery's state of charge as below the threshold for stop/start operation, 70% if I recall. MES will tell you what the BCM's SoC measurement is.
There is probably nothing wrong with your battery, just the car's 'intelligent' charging logic combined with the mileage and type of journey you do, isn't keeping the SoC high enough for s/s operation.
But as you say, s/s is best disabled anyway.
#34 ·
disconnecting the negative pole on the battery for 15 minutes or so will reset the IBS..... I would try that first, as it;s free ;)
(disconnect the actual negative battery pole, not the quick release as the latter will not disconnect the IBS )
Upon reconnection you will need to perform the reset to kill the error lights : with engine running turn steering to extremes, then center. Turn off, restart, repeat if necessary
#35 ·
I had same issues; did replace several relays, did the software updates etc etc. Although the alfa specialist was pretty clear: couldn't be the battery; my common sense told me otherwise! Keeping track of the car usage, I discovered a undeniable pattern. When driving longer distances between (re-)starts never resulted in any issue; however (some) low mileage trips, multiple starts or driving in "A" mode with low rpm: issues were waiting to happen sooner or later.
After replacing and upgrading the battery, engine stalled only once. Fully charged the battery about 6 months ago, nothing to report since then!
#36 ·
2024 and battery testing by garages with dedicated equipment still seems to be unreliable. How many times has a battery wrongly been given the all clear in the forum. Stick to the amateur tried and tested methods.
