Hello,
The eLearn for Alfa Romeo 159 lists a bit convoluted procedure for assembly of front wheel hub onto the drive shaft:
1. Tighten the nut to a torque 14.3 -15.8 daNm
2. Undo the nut by 90 degrees
3. Pre-tighten the nut to to 6.7 - 7.4 daNm
4. Tighten the nut by 45 degrees
5. Tighten the nut to 20 - 38 daNm
I understand why you need to tighten something to a specific torque and then also tighten through a specific angle afterwards but I have no idea why you need to do all this. Anybody with more engineering knowledge has an explanation why is all this needed?
Especially step no.4. seems strange. Why is it needed if you finish with tightening to a torque...
By the way... the local dealers don't follow this procedure and just tighten the nut to the final torque. When I asked them why is all this exercise necessary they just said "ehh..." and waved with the hand
