Front collision warning, check stop lights and check parking light failure
1.5K views 27 replies 7 participants last post by  mello yello
#1 ·
I got 3 different errors on the dashboard that I cant erase on MES "Front collision warning, check stop lights and check parking light failure"
The DTC code is B100C-92 - Rear left taillights - Performance or incorrect operation.
I've checked my wires behind the rear left taillight and there was nothing "I could" see and also BCM for any water damage but there was no any fog or water inside. I can't use my cruise control because of this and I just wanna know where the problem is instead of giving a ton of cash to a mechanic for diagnostic.
Please help me!
#10 ·
if all the tail lights are working as they should and you are getting a random error, coupled with the fact you say your cruise control is not working sounds strange
does your stop start work as it should ?
if stop start is unavailable coupled with random phantom errors, it could be battery related ... how old is the battery ?
#15 ·
ok, if the battery was replaced recently then IBS needs to verify a healthy state of health and that could take up to a week for it to learn - those errors could be persistent in the storage until the IBS clears the state of health of the new battery
does your stop start work ? even with the new battery that could take a while to work again
#19 · (Edited)
Ok, I thought that is what you meant, was just checking on an important detail
sounds like it didnt start working again till the next day, so does that mean it stopped working with the old battery ?
the reason I am stuck on that point is to determine or guess you may still be getting errors because the IBS has not learnt a healthy battery yet ... and it may disappear as soon as it does, ... so it may just take a few days for it to work its way through all the diagnostics ... then you may need to clear the errors again
just trying to eliminate the easier stuff first
#20 ·
Generally, the IBS takes hours rather than days to recalibrate after battery replacement.
The acid test is whether STOP/START and HRW are still working 2-4 weeks later.
If not, either:
  1. there is some stray current draining the battery when the car is off.
  2. the IBS is defective
  3. the car isn't driven long enough and often enough for the battery to be maintained at an SoC sufficient for S/S and HRW to be available
A large number Giulia batteries are getting replaced unnecessarily. Anyone suspecting a Giulia battery should eliminate 1-3 before getting a new battery. 6 years and 75,000 miles in my first Quadrifoglio without battery replacement. S/S disabled of course.
owns 2023 Alfa Romeo Giulia Quadrifoglio
#21 · (Edited)
mine took over a week for stop/start to become active after a brand new battery was installed ... which fixed the problem btw (bizzare errors like ECM BCM ACC infotainment, steering errors ) ... no headlights or tailight errors though,
OP could have two separate issues
many people report similar ... nowhere have I heard hours, and nowhere have I heard 6 years
a very high percentage of people who report bizarre problems like this have had them resolved after the battery was replaced, and not until the IBS re calibrates, and that time will vary
where do you get "many unnecessarily" from ?
#24 ·
You might choose to do an advanced search of this forum for all my posts which contain the word battery or SoC.
Many batteries have been changed because individuals address the consequences of a system issue not their cause
I didn't claim that the OP had unnecessarily changed his battery, but that many have.
I am a professional engineer with 50 years in design of complex systems and diagnosis of their problems.
#28 · (Edited)
so then why is it relevant ?
the OP said his battery was dying and thus replaced it - he then needs IBS to re calibrate and hopefully that will clear his persistent errors if it was the battery that caused this headlight/rear light/FCW problem with these errors
if not, then he may have a problem, but his battery was replaced for a separate reason
everything else is white noise, irrelevant and pointless speculating - you should know that you are an engineer
#26 ·
As well as SoC there are lots of factors that will cause the Body Computer to disable S/S. Things like the temperature requested and the temp it currently is in the car being significantly different. Mine never seems to work with the heated seats on when it's cold... There seem to be lots of parameters which will stop it from working tbh.
#27 ·
Following a recent illness, today was the first time in almost 5 weeks that I was able to take my 3 year old Giulia out.
It started 1st time and the HRW worked as it should, clearing the mist on the inside.
Stop/start I have permanently turned off so I don't know if that works or not.
Sorry you've been able to make little use of your Giulia recently, but very pleased to hear you're back behind the wheel again.
The 'Intelligent' Battery System will try to maintain the battery SoC at 80%. The HRW threshold is 60%. If there are no stray currents draining the battery, It will take several weeks to drop from 80-60%.
There are indeed a long list of things which can prevent S/S working, I recall @jwq published the full list 6 or so years ago. Its threshold, I think, is 70% SoC
But who cares that the S/S isn't working? It is bad for the engine and battery etc and is best disabled. HRW is another matter altogether.
