I am having an issue with my Giuliettas climate control. For some reason when set to AC the drivers side cools down nicely but the passenger side just seems to blow outside temperature air in when set to heat though both sides seem to be correct temperature.
In addition to this the passenger side vent labelled 1 in picture has slightly lower pressure than the vent labelled 4 (maybe just because it is on a longer pipe though) but vent 2 produces about 1/8th the pressure of vent 3. The same behaviour with temperature and pressure is noted when on the feet setting but when blowing up onto the screen it seems to be fine.
I have done the auto calibration procedure with the multi ecu scan tool which completed successfully but prior to that there were two errors logged (attached photo).
I'm assuming that one of the motors that controls the AC flaps is broken but have no idea which one or how to go about replacing it other than it will be fiddly. Can anyone advise?
