changing aux tensioner on 156 jtd
Tags
aux tensioner
4.6K views 14 replies 6 participants last post by  kevmjtd
#1 ·
Hi all can any one tell me step by step instructions on how to change aux tensioner,
i took the wheel off and took the plastic cover off and can see the tensioner im 80 percent sure this is the problem, i know i shouldnt spray oil any where near the belt but spayed abit on the tensioner wheel and this shut it up, when i rev the engine the squeaking came back! the car it shuts up on idle then squeeks when driving does this sound as if its the tensioner? dont want to waste money on a part i wont need, i have video recorded the noise can you upload videos to this site any info please thanks in advance.
kev
#2 · (Edited)
The tensioner is mounted by the lower bolt, however you first have to remove the belt
It's hard to get your head round if you haven't done one before, you have to place a large ring spanner over the bolt on the roller and rotate so that the roller moves downwards.
There's a fair amount of tension on it, it will help if you have an assistant to slip the belt off while you do the necessary with the tensioner.
You'll get there
All the best
Pub
#4 ·
http://www.ebay.co.uk/itm/alfa-rome...ensioner-/150767924592?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item231a77f570
The tensioner on the 2.4 engine is a bit different to the 1.9. I'm guessing the above part is what you are talking about? The pivots seize and stop it 'springing'. To be honest its not an easy job to change as tensioning the belt can be a struggle. If you search you'll find answers but there is another eccentric pulley to the right that is twisted to tension the balt against the spring tensioner.
Keith
#6 ·
Be careful undoing the bolt that holds the tensioner to the block, they can seize and snap off leaving you with a nightmare to get it out, if it feels at all tight work in back and forth gently helped with a bit of spray if you can get it behind the bolt
#8 ·
Hi Keith. Was it you that started a thread a while back showing how to free up the tensioner??
I have overhauled the tensioner I removed after 13 months of service. I did consider offering a service to forum members to overhaul them. There are a couple of problems with this though. Firstly I couldn't find a manufacturer who would sell me a direct replacement for the bearing or spring. I came up with a method around the bearing but the spring was a non starter.
I even went as far as getting the tooling and spares.
I'm not sure how many failures are spring related but for me the three that I replaced, two were related to the pivot shaft/bushes wearing causing the horrible rattling and one was the pulley bearing squeeling. My method of overhauling cures both these issues.:)
#9 ·
Nope not me. I just followed someone elses tip! My bearing and spring were fine but the pivot had just started to stick. I caught it just in time as the bush was fine. I''ll probablyhave to replace the whole thing next time as the bearring will probably be going but at ÂŁ100 a shot it had to be worth a punt!
Keith
#10 ·
someone was saying theres no grease in the allen key bit (if you know what i mean)
and to grease it up your self, yes steve thats the tensioner im on about found it for ÂŁ103 at euro parts.
#12 ·
Help help please, Ive know changed the tensioner, and put the old belt
Back on, all was going well and then the outside of the belt started to strip
I put this down to the belt being old so changed the belt, all looked good no squeaking
Belt looked good nice tension I drove the car to work and back decided to check the belt and same
Problem again its striped the belt from the outside, I can't understand what's gone wrong as the belt is guided
Has anyone else had this problem help please...
#13 ·
Something is out of alignment. Check the bearings on the other pulleys including the alternator and Air Con. Also check that the new tensioner is sat correctly. Seem to remember that there is a thin washer behind the tensioner and there is a shallow counter bore that the pivot pin sits in.
