Brera Front Badge Replacement Guide
Tags
guide
1 reading
11K views 18 replies 10 participants last post by  davej311
#1 ·
So I finally got round to changing my front badge and decided to post what I did for anyone who wants to do this on their car. I believe the 159 will be the same.
There are lots of posts on here that say what you do but I never found any pics besides before and after which is why I am posting this with steps to make it as clear as possible for people who don't normally do diy on their car (like me!).
Tools
Hammer, Nail, Long Pliers, Cloth/Rag, Bug Spray (just because it was handy).
How To (Click Here For Images)
First gently tap the nail into the badge below the center and continue to do so until you make a hole big enough to get long nose pliers through. Then use the pliers to twist the old badge and remove. I also used a cloth to protect the rim from any damage.
Then I cleaned up with Autobrite 'Just the Tonic' Bug & Tar remover (Hopefully I will get paid for advertising.....) and removed any backing tape left so the surface was clean.
Before going straight into fixing the new badge put it on without removing the tape cover to check it sat right and was happy I would be able to put it on straight first time. The replacement badge I got had a protective cover over the face so I lifted this off the edges which allowed me to put the badge on and then easily remove the cover after.
Job done! Took about 10mins (removing sticky residue takes up most of that time)
#3 ·
Looking at the state of the badge that came off, it looks like you put the nail in above centre rather than below, as in your instructions.
Are the instructions with the benefit of hindsight having discovered the indent below the middle?
Did the new one have an adhesive backing or did you glue it on?
Did you consider fitting one of the new style badges?
I still can't decide whether I like the new ones or not...
#4 ·
Regarding the ease/safety of removing the whole badge unit first:
1) the rim around the badge is still part of that unit so would be at as much risk of damage in either situation
2) it would have been a longer job
I did go above the center like a tool yes so had to sand it down a bit to ensure the surface was smooth. At least it was all hidden after the job was done thankfully. That's the main reason behind my post as the image without the badge shows clearly where you can start 'attacking' from. Always good to learn from peoples mistakes too.
The Badge I got came with an adhesive backing so it was straight forward.
I never looked into any other badge styles to replace this as I personally am one of those in the 'keep it original' group. The only exception to this will be when I magic up enough money to replace the head unit for something decent.
#8 ·
Harribone - I used a slightly different technique for the rear.
There isn't a hole behind the badge for a nail (or other sharp implement) to go into. The way I found easiest was to get a small flat-head screwdriver and ease it under the rim of the badge from the bottom, again with a cloth to protect the silver outer ring. If you push the top of the badge in, as if to open the boot, it should tilt the bottom out enough to get a very thin screwdriver in, then you can slowly work it upwards behind the badge to start prising the badge away.
I was a bit too pre-occupied to think about taking photos as I went, but here is a before and after:
#10 ·
I have done my rear one now and on the push type you can go through the badge with a nail if you want, there is a small indent in the center which you can work with. I did this before I saw your post barners about approaching this from the edge but I still would have gone with the nail approach because id rather scratch the area which would be hidden than the edge, great job though with yours!
The only issue I found with the rear is that my badge didn't sit right, the push button was slighty to big for it to rest on perfectly. The basic guid I got with the badge suggested adding a layer of double sided tape to the back of the badge to help this but I decided to bend the egde of the badge out a little so it would fit correctly over the push button. This also meant I had the remove the little tab on the badge which is used to help line it up. I managed to rest the badge on and then used a spirit level to get the center line of the logo vertical before pressing into place.
Note For anyone who is reading this with a view to changing theirs - the indent in the center is for the push type Brera badge only. I have no idea what the standard badge is like underneath and with the 159 I know that the push type is a different part so might not be the same.
#15 ·
Yep, I'm favouring the original also.
Just far more interesting with the colours, and catches the eye more.
