Anyone used, or using a 10w50 oil in a t-spark engine?
Tags
10w50 tspark
12K views 25 replies 11 participants last post by  GTVScotty
#1 ·
Hi all,
My car burns a lot of oil, I use 10w40 semi synthetic as that is the "correct oil", I am just curious as to who uses a 10w50, as I am thinking of trying it so see if it makes any difference. I have to put in a quater of a litre about every 200 miles, so I am spending rather a lot on oil at the moment, so any suggestions on any oils which would reduce this amount would be appreciated. Thanks :)
#3 ·
Alfa originally specified a 10w-40 semi synthetic or a 10w-60 fully synthetic. Anything in between (such as 10w-50) will be fine as well.
Oil consumption can vary between different brands, even if the viscosity is the same, so using a thicker oil won't nessesarily make oil consumption lower.
I found that TS engines run best (quieter and smoother) on a 5w-40 fully synthetic.
#4 ·
If it was me.... with that kind of consumption I'd be a bit worried. Try to work out why the beast is losing oil and fix it.
Meanwhile, the Big H. sells 15W/40 semi synthetic (purple can) which should cut your consumption in half and may be cheaper than bunging 10W60 synthetic in there, until you fix the real problem.
Ralf S.
#5 ·
10w60 was only originally specified for the 2.0 JTS engine. It was never specified for the 1.6, 1.8 or 2.0 TS engines.
I agree with Symon, a fully synthetic 5w40 is the best for your TS engine. I've been using this spec now for over 5 years in the 916 Spider, and it never burns any oil. Selenia actually do a very good 5w40 oil, but there are plenty more on the market as well.
I personally never rated the Selenia semi-synthetic 10w40 oil as specified for these engines. It always went dirty very quickly and even with every oil/filter change at 6,000 miles it looked in a real state.
A fully synthetic 5w40 will be the best for your TS engine and will help a little more on those cold winter mornings.
#6 ·
10W60 WAS in the manual for the TS engines with a note saying something like "for sporty use".
The 2008 147 manual I've just looked at has 10W60 for the 2.0TS and 10W40 for the 1.6TS.
As for the oil looking "dirty", the dirt will be in the engine, if it isn't held in the oil you have to ask yourself where it is...!
An oil that comes out still looking clean at the oil change is not necessarily a good thing.
#7 ·
Thanks for all your replies.
When I changed the oil last I used Nulon Fully Synthetic 5w40 as I managed to get hold of some very cheap, but within 150 miles it was pretty much down to the minimum on the dipstick. I am now, and have been for the last 400 miles topping it up with Nulon 10w40 Semi Synthetic, as that is what I have always used, and have litres of the stuff. Maybe it just doesn't like Nulon, and when it comes to the next change I shall try Valvoline 10w40 as I have a couple of 5 litre bottles of the stuff.
Ralf, I have looked over the car, and I can't find ANY evidence of leaks anywhere. I really can't be bothered with any problems with the engine on the car, as the car has been a nightmare and a money pit since I bought it in January, but the engine has been faultless and I really want it to stay that way :confused:
#9 ·
When I got the Alfa in '98 the oil consumption was the normal 1 litre in 1000/1500 miles ... in 2003, after a cambelt problem, I had the piston rings replaced as they were showing signs of tiny cracks, plus there was a scratch on cylinder 1 .. not a deep scratch but visible to the naked eye.
Now ... hardly any oil is used in the six months (around 6000 miles) that I do an oil change. I have a couple of small oil leaks .. visible on the engine ... think it could be the cam cover gasket.
And that's on Selenia Semi 10/40. Always used it ..
Probably not what you want to hear though ..
#11 ·
Hi Cretino,
I am topping up so little and so often because it is required....You are right in the fact that it doesn't NEED to be at max all the time, but I want it to be at max all the time. I do a lot of long journeys (240 mile round trips) so I always check the oil before hand, and with the consumption being as it is, I wouldn't want to risk it burning it all, therefore I always keep it on the maximum line.
I don't really agree with you on the holding out until it is just over minimum....for what reason would you do this? Surely it is better to err on the side of caution and keep it topped up as much as possible.
#12 ·
The idea is that the sinking of the level might stop somewhere between max and min.
the engine might use much less than you think. Find out how much is the difference between min and max in your engine and use that to predict how long you can go. CHECK verry often but only top up when you have to.
I was thought this by an verry old mechanic a long time ago and since have seen this be true with many engines , both HGV and cars. It has something to do with the airpressure build up in the carter i think.
If for modern engines is no longer true maybe some one can rectify.(maybe diff between max and min has become smaller).
#19 ·
Anyone who's followed my posts will know i had similair issue with oil consumption...over 5 weeks i used 5ltrs of 15w/40 Halfords semi but in the last couple of those weeks the oil consumption dropped considerably & i then put MOBIL Formula 1 10w/60 fully synthetic in & it has stayed just off max for two weeks now with spirited driving!
Reckon the oil in the sump when i picked it up was cheap thin stuff..possibly like yours mate..i have no visible signs of leaks either so fingers crossed yours will settle down with an oil change. Good Luck.
#20 ·
Nice one, I have got myself some Gulf Competition 10w60 fully synthetic which is going in tomorrow when I have access to some ramps. Hopefully it will solve the issues, and I am glad to hear it solved yours :)
#24 ·
These engines seem so accumulate a lot of oil residue.. and if so.. maybe the oil rings are gummed up a tad..
It maybe due to the use of Selina in the cars early days... A few short changes using Castrol or Shell or something may help clean things up a bit..
