Alfa 159SW TI 2.0jtdm 170hp Maf/intake problem?
5.9K views 53 replies 10 participants last post by  Jetronic77
#1 ·
So i bought an alfa 159,195k km.
Problems happend the very next day i get p0130 o2 bank1 sensor 1 error so i got a new o2 sensor and put i it after 100 km the sensor is dirty like the old one.
Car has dpf delete and smoke allot i mean allot,clouda of black smoke.
I unplugged the MAF and the car smokes less now but i get MAF check engine.
MAP is like new so i assume the EGR is blocked/deleted in ecu.
And the car is slow below 2200 rpm,turbo gauge indicates that turbo is ok i guess and 0-100 is around 9.4 sec, fuel consumption around 7.7 l/100km.
Also the air intake head was replaced with a new one so no flaps problem.
I would be happy for any info where to start so i can fix my black love. :D
#2 ·
Black smoke means over fuelling, too much fuel, not enough air, so this may be an indication that you have a split/leak in one of the turbo hoses. So get the car up on a hoist or jack stands and take the undertray off and check all the hoses from the turbo to the intercooler, from the intercooler to the throttle body/intake manifold.
It may also explain the lack of power below 2200 rpm as air is leaking through the split/leak till the turbo spools up enough to compensate the loss.
It's a place to start at least.
#14 ·
As far as I'm aware there is just a DPF in the 2.0. I know some one who smashed the honeycomb stuff out of his DPF.......it all looked to be the same to me.....not two different materials. And its not a tube on the 2.0 but a big silencer shaped thing going straight down the front of the engine.....like this...
Could be wrong though!
#22 ·
Ok, that's fine in this instance, but everybody need to understand something. While generic codes readers will read the code number the Alfa Romeo code descriptions can vary greatly, Alfa Romeo does not always designate the same code number to the same fault. (Typically Alfa)
For example a certain fault code number in the ABS system on the standard OBDII code listing describes the fault as a faulty Valve Solenoid in the ABS block, however Alfa Romeo uses that code to describe a faulty Steering Sensor. This is just an example, there are so many more instances like this, DPF Temperature & pressures sensors, Body Computer errors and so forth, hence why I always recommend using Alfa Romeo specific diagnostic software.
Otherwise one can go chasing down some very dark rabbit holes by mistake.
#33 ·
Check the preheaters, maybe you don´t have a mistake but one or some of them is heating poorly. I´ve changed recently one which game me error (nº 3) I mesured and gave me a value of 8k Ohms, but i´ve realised that it had to be wrong weeks or even motnths ago, now the engine starts smoothly, and I´m sure that another is on the way of be broken because it gave me a value of 8 ohms when it should be between 0 and 1.
