Wiper problems with 156s tend to be failures in the control pack which is integral with the motor - a good second-hand unit is the usual fix, and only a 15 minute job. There are two different types, changing around late 2001 IIRC so check that you get the right one - obviously earlier ones are easier to come by....I've a few of them.
Thanks il go up to a breakers and get one
do you know anything about the central locking
I have to hold down the passenger side lock down wait then lock the back doors and then lock drivers side with a key I have no idea I'm new to alfa's so all new to me
cheers
Sounds like the passenger side lock has got sticky...if you try to lock it from the driver's door - or the passenger door - do any of the other doors try to lock? If one is sticking, they will try to lock then they will "bounce" back open......
I suspect in the 12 months since the problem was posted he might have solved the issue
:thumbup:
Related Threads
Alfa Romeo Forum
posts
7.3M
members
228K
Since
2001
