156 front fog lights and dash bulb...
1.8K views 11 replies 7 participants last post by  Gilbertr14
#1 ·
Any idea as to why my front fogs arent working ?
I've replaced the bulbs, tried to turn them on yet get NO display on the dash and no illumination from the lights !
The bulbs are seated correctly, the fuse is OK and the loom is plugged into the rear of each bulb housing.
Is there arnother connector in the engine bay that may have come loose?!?
#10 ·
Gilbert - If it's the same as my car, both front fogs are powered through a single 15A fuse in the compartment above the glove-box, and the relay is in there as well as David C thought. Gav - Check for a voltage at the switch, as Irish suggested. The switch puts one side of the relay to earth to switch the lights on and off.
The fogs should work with just the side lights on - an improvement over the 155 which needed the headlamps to be on and thus making the front fogs useless.
