Bit of advice required here Gents (or Ladies!)
Here's the scenario : A friend of a friend! has a 51 plate 2.0 T/S which has suffered timing belt failure, resulting in broken valves & holed piston crown in No1 cyl, basically the engine is beyond economic repair. I am in possession of a 99 (T reg) 146 1.8T/S that I am breaking up and have been asked can the 1.8 engine in it be used to replace the broken 2.0 in the 156? (He's not to bothered about a small loss of performance)
I know this conversion is a little out of the ordinary but what are your thoughts guys?
Is it just a case of fitting all the ancillaries from the 2.0 engine on the 1.8 engine or is it more involved than that? What problems could you foresee? Do any AO members have any experience of doing this?
Thanks in advance
Thanks in advance
