JTS Hub for 1.9JTD car? (156)
Tags
19jtd hub
563 views 2 replies 2 participants last post by  Boxy
#1 ·
Hi all, the hub on my JTD is knackered, there is a JTS being broken not too far from me and I was wondering if they'll fit? I now the carrier is the same but if the driveshaft splines are the same?
#2 ·
Driveshaft splines are the same, but the ABS sensor plugs are not necessarily the same, compare them both before purchasing. As a rule, ABS sensors will break if you attempt to remove them so I usually sell 2nd hand hubs complete with the sensor attached.
#3 ·
Pud, I've read a lot of problem posts on here over the years and you seem to pop up a lot with the solution!
I had a feeling this was the case but just wanted confirmation so thanks, I'm not too fussed if I goose the sensor on the replacement hub as I was lucky enough to tease the sensor out on my own hub a couple of times already and always stuck a bit of copperslip on. I know its plastic but it seems to work :)
