Fat mixture - what to do?
Tags
fat mixture
763 views 5 replies 3 participants last post by  GTA Jim
#1 ·
Hi!
Got a 33 16v that gets too much fuel.
I ve changed the following;
Lambda, Plugs, plug-wires, idle valve, injectors, cleaned airfilter..
But the idle still is bouncy, and it can drown if i`m not rev`ing it.
any ideas?
#3 ·
Thought about it.. since i have a kn open air filter. Could it be that it has been "filled" with oil after i cleaned the filter? I was careful with oil`ing it, and i did let it "dry" for an hour.
Is there a way to check if the air flow meter is the sinner? can i disconnect it?
#4 ·
Disconnect it :D
#5 ·
hehe.. sure. that looks convincing! :thumbs:
If i disconnect it, it will go into a pre-made program, right?
My thoughts; Then it will give a certain amount of fuel at a pre-set rpm. Which will not be the correct amount, since i`ve got a different air filter system etc. But i should notice a change.
But will that exclude or solve anything?
#6 ·
Dont know mate but when I had problems with my MAF I just disconnected it and it ran fine. Best thing to do is do the same and have a drive and see if the problem is still there.
