L
1. you must have had that door car off before, some of the bolts pratically fell out. Also when showing removed bolts they are out of frame
2. you could say sizes of various bolts been removed + the tool required
3. the two 10mm thats behind the door switch they could be 5mm allen heads
4. unless you remove the triangle piece of the door at the mirro it make life harder when fitting it.
5. on non-Bose system cars the tweeter also has a 2 wired connector that needs to be removed.
BTW if you can fit it as fast I'd be very impressed :)
I did take door card off before just to make sure all bolts where there and just slackend them off a little so speed up the removal to cut the length of the video down. Will be getting a light for the next one will also be showing bolts and tools needed.
