Gents,
I have 159 ti 2.4 which for some time now has had some play in the steering most notably on the motorway when changing lanes or when going over crowned surfaces.
To this end I had her checked out by a specialist who told me that It was the bushes on the lower arms both side and also on the left upper.
I got her booked in to be done, the lower bushes were replaced with a poly bush but they told me that the upper did not need doing as there was no play.
I also had two contis put on and the alignment done all was good the car came back feeling so much better but not 100% I still felt there was a little play some where
A year or so later during an MOT I was told it need it upper left wishbone replacing bushes gone. so I booked it in to be done and same again they said although the bush looked deteriorated there was no sign of play.
I am now looking to get to the bottom of this and get it sorted out but every garage I take it to get checked out say there's nothing wrong with it ( apart from when shes up for an MOT)
The only other thing I have noticed is the steering wheel likes to sit slightly to the left , you can hold it straight and the car goes straight but if you let go of the wheel it will sit slightly to the left but the car still goes straight. Some times when accelerating perhaps going from 1st to 2nd gear I can sometimes feel the steering wheel give a slight pull to one side which made me think of the track rod ends but again different garages tell me all is okay.
Your thoughts please gents (or anybody)?
the car is 2010 model I have had for three years it has around 78k on the clock the suspension never makes any noises and the ride is whisper quiet
What are the symptoms of upper wishbone failure ?
could it be track rod ends ?
to anybody who's had the uppers replaced what were the symptoms ? and what did replacing them fix?
Any help would be great thanks
