1 - 10 of 10 Posts
My car has headlight washers fitted, but No xenon headlights.
I have seen a lot of cars with no headlight washers, and the ones i have seen with them have had xenon projector lights.
Does anyone know what the factory options were?
Headlight washers were part of the winter pack I believe. Xenon lights were an expensive option hence why not many had them
What is required to upgrade to headlight washers?
I accept that the bumper washer in the rubber strip is required.
Is it a different washer bottle or can the pump + plumbing be replaced alone?
Do they wash every time the windscreen is washed? If not, how is the logic built in to the system or is it just wiring?
Any wiring diagram?
Any wiring diagram?
Wouldn't bother with all the aggro , they are not very good .
The Alfa system runs every time you wash the screen when the lights are on, so you rapidly run out of screen wash in the winter.
Bit of a pain really.
The ones I used to have on my mini were the first and then every third after that. Plus they had their own bottle so if they ran out you could still was your screen :thumbs:
There is a timing relay in the Alfa system too, but it is still far too often.
On a winter run up the A1 from London to Lincoln, the washer bottle (5.3L) would be empty by half way...
Agreed, they use far too much screenwash. they only spray, when the headlights are switched on. I have pulled the fuse on mine, as one of them leaks, so i need it fixed.
Just wanted to see if the winter pack with headlight washers, included xenon headlights
No.
But having HID headlights got you the washers too.
1 - 10 of 10 Posts
