Hello Dan!
Hope you're well, yes, thinking of doing a bit of a project based around the cadamuro style front bumper I had from you...going to add a zender front splitter to fix the bottom damage, then modify the front bumper mount for better airflow and squeeze in the biggest fmic I can find ( the wide spaced holes for the front fog lights should mean I can still have lights and fmic), then run ally pipe and maf to a large cone filter below the headlight. Then fit an oil cooler where the old intercooler was, and bracket for a remote oil filter/ thermostat where the old airbox was ( have actually already deleted the egr, cooler and the vac controlled cut off flap!). Did look at the 16 v oil cooler take off, but the corrosion associated with them put me off....think I'd rather use a brand new side take off blanking plate; not too expensive, and plenty around. The alloy race rad would look nice next to the fmic...as far as the pipe work goes I'd either look to get the rad bottom pipe connection altered, or make a hard pipe to connect the original jtd hose... All really aimed at increasing the tuning potential...before I get a remap!
All the best
The Captain:thumbs:
