hi everyone need a bit of help/advice?for the last couple of weeks my 156 has been playing up,its ok for days then suddenly it doesnt want to start,the engine turns over but doesnt seem to fire,earlier on today it took nearly half an hour to start.could it be the coil pack or starter motor???thanks in advance,mark.
Could well be as Lacken suggests.....is there any pattern to the none-starting - if its only when warm, then it definitely points to the crank sensor. Are there any warning lights displayed - in particular is the code light coming on and going off within a couple of seconds?
If the engine is spinning over normally it definitely isn't your starter, and as your car has either 4 or 6 coil packs depending on whether it is a 4 or 6 cylinder engine (and assuming it is a petrol:lol:), a coil pack failure won't cause a none start - just a misfire.
yeah got to be the crank sensor only about £40 on ebad i think,,,,
anyway works doo tonight:vomit:
there is no real pattern to the non starting,just now and again whether the engine is hot or cold?
D
As RGWM asked are there any lights staying on when it doesnt start or indeed any of the regular ones not coming on ?
And petrol diesel 4 cyl 6 cyl ?
hi dav,there are no extra lights that come on and none that stay on,it is a 1.6 petrol,4 cylinder.
