1 - 20 of 45 Posts
C
FIXED NOW 17/11/08- see later post
Hey guys,
I need some info on what this could be.
Symptoms:
1)My car accelerates ok but as soon as 5200rpm is hit the car sudddenly stops accelerating (like a smooth limit, kind of pulsates)
Occasionally breaks through but only slowly or not at all. (edit: Now gets through but hesistates)
2)Cars been running cold 50-65°. removed tstat yesterday, found it sat 1mm off seat so i removed some of the expanding wax stuff so that the rod slid further up. Checked it in a pot and now closes fully. Reinstalled in car, now runs at 70° (edit; Now new one fitted, runs 73gauge=85 ecu, to 90 gauge 95ecu)
3)Annoying Cold starts where depsite applied throttle, won't accelerate, engine pops if additional throttle. Goes away after 20 seconds (edit: still happens, worse on hot days as summer is upon us here in nz)
4)Full throttle is weaker than say 80-90 % throttle
History:
Serviced 2 months ago oil, oil and air filter, plug check, cleaned maf. Fine before service, felt it was lacking balls after service but may have been placebo.
edit: new thermostat fitted)
Things I've tried:
have tried driving hard with MAF disconnected, although rougher elsewhere, this didn't change the high rpm symptoms. New thermostat and correct running so this not an issue.
I wanna know what you guys think.........
1) You need a new MAF sensor
2) You need a new thermostat. (it should run at 90)
3) see "1"
C
MAF - That was a suggestion elsewhere too. But I tried driving without the MAF connected and fault was still there.
I think your right about the thermostat - cold starts woldn't induce an rpm and throttle limit would they?
Just noticed you said "plug check" during the service.
Why was that?
You can't regap them, you just leave them alone for 5-years/60000miles/100000km then replace them.
Also, why did they clean the MAF if it was running ok...?
Definatly the MAF, I had the same problem on my first 156:D
C
They looked at the 3 front plugs, they weren't showing any signs of issues so they didn't replace them.
Yeah MAF thing annoys me as it was running fine. They were trying to be helpful i think. worrds were something like "Alfas tend to have issues with the MAF so we gave it a clean for ya"
I'm more - "if it aint broke, dont fix it" mentality
C
No idea - only owned car 2 and half months. Car imported into NZ from japan a year ago - no history
:cry: :cry: :cry:
Perhaps the rears are the originals.Everyone has done this:D
Yep that could have knackered it.
:thumbs: :D Me 2
Pomeo
How old is the car?
If you don't know, send me the chassis number in a PM.
Also, what is the total mileage?
1998, 76000km
Has it had the cambelt replaced yet?
If you don't know, CHANGE IT, plus the tensioners and fit a GTV 3.0V6 waterpump.
Exactly what david has advised.And the plugs too.
Pomeo
C
Discussion Starter #15
Yeah was planning to do Cambelt etc this month - until this other stuff became an issue. Wanna get this sorted first. Thanks for recommending GTV pump - Will look into the differences outside of this thread
Thanks everyone for replying so fast - this is a great forum from what ive seen so far
GTV 3.0 pump has a metal impeller, all the other V6 pumps have plastic impeller and crack/melt.
C
Discussion Starter #17 (Edited)
Since service it wasn't a sudden change. It's just become worse and worse over time.
If it was the MAF then the high rpm limit would have disappeared when the maf was disconnected eh?
My theory so far is
Running cold cos of tstat -> rich mixture which overworks the cat -> catatytic converter either blocked or molten due to being overworked by rich exhaust.
Others theories-
Needs to be ecu reset since maf was cleaned (reset)
injectors blocked, fuel filter blocked (remove and clean, replace)
Running in cold mode so limiting throttle and rpm (replace thermostat)
Blocked CAT (replace with resonator)
And of course just MAF f***ed (replace or clean)
Still keen to hear more thoughts on this.
we have no emissions limits here so will get cat removed anyway, and will source and replace thermostat with new one. If they don't fix it then I guess the costs will start to skyrocket
There isn't a serviceable fuel filter.
C
Discussion Starter #19
Yeah apparently it's an expensive replacement too. Am avoiding changing fuel filter like the plague (hey isn't that what the lemon guide said about the 156 - haha they way way too conservative with their recommendations)
Blocked fuel filters has never come up as a problem on here.
So don't bother with that.
1 - 20 of 45 Posts
