Hi Alfa Peeps;)
A quick bit of advice needed. Can anyone confirm or deny whether a set of the white WolfRace Prolite 17" alloys will fit my Ph3 GTV? I know that the PCD is 5x98mm on the GTV (from other posts), and the PCD on the Wolfies' is 5x100mm. The tyres are 225/45/17 so I know these are OK but not sure of the wheels themselves. Currently have a set of 16" Teledials on at moment.
Any advice gratefully received :thumbs:
You have to check the ET value and center hole on the WolfRace rims as well.
The GTV require 58.1mm center hole and an ET value of 30.5 (2.0 TS).
With the 5x100mm PCD then you will need some excentric wheel bolts.
If the center hole is larger than 58.1mm you will need some center rings.
If the ET value is higher than 30.5 then you might need some spacers.
