1 - 15 of 15 Posts
Definitive answer needed :)
Is changing the front wishbones a fairly straightforward job? I.e.
1.Any special tools needed (other than a set of spanner/torque wrench/socket set)?
2.Spring compressors needed?
3.Anything else that needs to be changed at the same time as the wishbones?
Vish
Discussion Starter · #2 ·
Hi Vish.
You don't need any special tools - may be a bit of brute force :)
No spring compressors - you leave the strut assembled.
Check your droplinks & ARB bushes while you are down there..
A
Hi Vish;
It's pretty straightward - make sure you have a nice long pry bar and a variety of beating tools handy though.
Try EB Spares if you've not already bought them, they do very good pattern parts for £97 the pair - inc delivery & vat.
you must have the tracking done.i bought my arms from my local motor traders for £40 each.
i was pricing wishys the other day and was asked if i wanted cast iron or steel ????? anybody else heard of diff ones like this?......
FLETCH think they mean the rear bush mountings whether they are cast alloy or steel
When i got the POWERFLEX kit it came with two sets of bushes for the rear depending on whether they were alloy or steel mountings
Hope this m
akes sense....... to someone
thnx mate but he was quoting refs from 2 piccys of front wishys that looked the same strange , but your reply does make sense.
Think that will be coz the wishbones come with bushes and mounting brackets bonded onto them
So there will be two types one with alloy brackets and one with steel depending on the size of the rear bush
And when you fit POWERFLEX you have to burn the bushes out and use the exsisting mounting brackets
are we talking about the rear bush on the wishy ? never new they had diff ones and ive changed my wishys in the past !!!!! does this mean there is a specific one for the type of car or is the mounting bracket fixing points the same and they just provide the right ones for the carrier wishy ? thnx sorry for goin on :D
yes its the rear bush all i know is that they do two different size bushes
dont know which one fits which model
Over to the technical guys
1 - 15 of 15 Posts
