Hi - I have recently acquired a 156, 2.5 v6 Sportswagon to scratch my Alfa itch. I don't use it every day but keep it for weekend runs. I am busy fitting a set of Smith gauges in the dash. I am a bit stumped on the ammeter. I thought I could just run the 10 gauge wire coming off the battery positive through the ammeter and back again to complete the circuit but I get no readings what so ever. What I know about electrical circuits and wiring is frightening so I am hoping someone here can give a bit of guidance. The voltmeter and oil pressure gauges are perfect.
There are some problems:
Your alternator can produce 120 Amps (probably) which is far too much for the 30 A gauge.
Both the positive and negative side of the alternator share the starter’s cables so some re-wiring would be required* to separate the positive side. Assuming you have a fuse box directly connected to battery positive it too would have to be re-wired.
So it’s possible but difficult. The voltmeter tells you most of what you need to know about the electrics, so how about an oil pressure or temperature gauge? Probably more useful in a hot climate (though I don’t know where you would fit the sender).
* The starter draws up to 1000 Amps so it’s current must not be put through the gauge.
Edit: Oil temp gauge! I've just seen you have pressure already.
Thank you, RT for the advice. These gauges were my Dads and came out of his Guilia Super so for me, its sort of a legacy thing to show them off in an Alfa.
I doubt I could find a matching gauge to replace the ammeter as these are about 50 years old. I may make a new backing and just do the two gauges.
There may be a circuit that only draws partial amps which can be measured. The data would be useless but the gauge would work and that would be fine for me.
I took a look and old Smiths gauges are available on ebay and new lookalikes from various places, but I take your point about originality. Good luck with it.
In the "old days" the ammeter was wired in series with the main output of the dynamo or alternator (most of which were about 45amp) .. I don't think "moderns" use the same wiring principles ..
A volt meter would be easier ..
If these are Smith's gauges, you can still get them for classics ..
