hi there, my passenger side wiper arm flew off yesterday. i found the arm and the spring and both are in tact. but how do you get that spring back on as very tight and i can`t even pull the spring apart on its own! any ideas or hints? thanks
Alfa Romeo 156 JTD 8v Veloce (2005)
Never done this myself, but have encountered rear brake shoe springs which are just as strong i guess.
Technique I have used is to force the flat blade of a screwdriver in between the coils of the spring (at least 1 turn from the end) - hook the spring over one end and use the screwdriver as a lever to hook the other end. I guess for this, take off the wiper arm to avoid any damage to the car and to be able to get to it easily - and be careful of the chance the screwdriver slips out of the spring when under tension.
Err, if the arm flew off I guess the little casting which is the hinge is broken...isn't it?
wrinx
