1 - 2 of 2 Posts
Hi, my windscreen washers are not working, when I pull the stick to give the windscreen a squirt nothing comes out and I can hear no noise either. I take it that if the nozzles were blocked I'd at least hear the motor? Seeing as I can hear nothing I assume that either the motor has died or the fuse has blown. Does anyone know where the windscreen washer fuse is located, and where the actual motor is located as well. Any other ideas welcome!
Cheers.
Dunno which fuse sorry, but the motor should be audible & is located on the side of the washer bottle, I had to replace mine a while back, sourced one from a local motor factor (meant for a ford IIRC, but was a perfect match)
1 - 2 of 2 Posts
