just bought a 155 V6 and the windscreen wipers are driving me mad....if you have them on constant they are fine.....if you have them on intermittent the wiper blades jerkily move back to their original position.
is this a common problem ?
Discussion Starter · #2 ·
Hi Nick
This is a VERY common problem. There are a couple of fixes you can try.
1. Replace the wipers with the AO shop conversion arms
2. Clean the motor. Try the search function (to save me typing it all out) for full intruction on this.
wrinx
Hi Nick,
This is indeed a very common problem, if you get the whole wiper system changed the problem will return within 30000 or so.
I have learnt to live with them and they do improve after being used constantly on full wipe, but it does take about an hour.
You can get bosch wiper arms and blades which are much better than the standard fitment ones which wear out and fall of the car when you need them most. Also the bosch ones don't hit the bonnet.
Try Alfa Aid who are resonable close to you on 01628 788887
Ian
Rain X is a great help on your windscreen for ensuring that they move smoothly
Hi Nick,
Had the same prob with the wipers on omy V6, so removed the motor and mechanism, cleaned the electrical connections with degreaser, and then refitted the mechanism using the wiper conversion from the AO shop (highly reccommended!)
Must say they're 100 times better than before, and don't knock hell out the bonnet. The jerky action only lasts for about 1-2mins on intermittent now (when it does actually happen)
Mark. :)
Mostly I can stop the jerking by putting them in highest position for about 30 secs, still I think I'm going to clean it before winter
I fitted the conversion kit to my 155 and improved the wiper operation immediately so I was pleased. The main thing I noticed after fitting the new arms/wipers was that the wiper motor was now having an easier time due to the new arms being lighter than the old shovels.
