My wipers have stopped working on 1st & 2nd speed. Having checked the column lever and wiper motor I suspect the Electronic Windscreen Wiper Intermittance (N14) may be faulty but cannot find it. It is not next to the fusebox as shown in the manual. Any ideas please?
I had a similar problem with one of my cars N14 is held in place by two allen headed bolts it is a bit of a fiddle to get to, If i remember rightly it is a brown box about 3ins x 2 ins with a multi plug at the top end, They usually somehow get water in them and this then corrodes the internals when i refitted mine i drilled a couple of small holes into the bottom of it just in case there was a leak and water got into it again at least it could drain out.
Found it!
Thanks guys :) I have found and removed it now, but even with your excellent photos it was difficult to see - a well camoflaged black box on top of a black bracket. It looks like the culprit as well with one relay's contacts all corroded.
Anyone know a good chiropractor?
