Windows 10 on my Asus convertible is taking up
50Gbytes on a 64Gbyte SSD.
The culprit is C:/Windows/Installer
Which has 19.7Gbytes of .msi & .msp files.
How to clean this O/S install guff off safely??
Ta.
This not not likely easily achievable. The .msi files are referenced when the system tries to update the O/S. If they are not cached
within the parent O/S drive, then this could risk causing serious problems when Windows
gives you no choice but to update the system.
This highlights the problem with onboard SSD storage. Even gaming systems have a small amount of storage, mine is 250 GB and Windows dominates the SSD. Beyond this, it moans when there is less than 25% of the SSD remaining to us. :irked:
Even worse is the fact that the OS cannot seem to be switched from the SSD to a slave hard disk drive because of the boot order in many Windows 8/10 systems. The HDD is often hidden from the BIOS behind the SSD! This was a problem I ran into when I tried to dual boot my system.
I'm sure there is a way of swapping the system onto the HDD (assuming you have one), but I'm not really that acrobatic with BIOS.
