Ah, new gremlin with the 155... :rolleyes:
This time the driver-side electric window comes up normally about half the way, then seems to rotate 45 deg. forward... Looks like a sort of rail guide that was fixed on the rear, vertical side of the window, disappeared??? Is that a common issue? :confused:
Pierre,
You're going to have to operate...
Take the door card off and have a peep inside. The mechanism is quite simple realy, so you should be able to see what the problem is if you raise and lower the window without the door card in place.
Ralf S.
