Hi People. Few months ago I purchased my very first Alfa and opted with the 1.9 JTD GT and I absolutely love it.
I do have a problem with the windows tho. Long story short, the drivers window was stuck in the down position so I stripped the door panel to if a few wiggles would work.. It never! My neighbour did have a tool though which could test the circuit and managed to get the window back up.
I done a bit of research and done the basic quick tests, and replaced a battery as it was still under warranty and a kwik fit test read that it needed replacing. Still no joy with the window going back unless you use this tester tool of my neighbours... Hmmm.
Shortly after the starter motor failed, replaced that and brilliant, we're back on the road. I noticed today though that the passenger window failed to work at all (was working fine before) with the passenger side switch but is fine on the drivers side switch.
Both windows drop/raise the usual inch or so when you open/close the door and I am baffled. Is there a fuse to control this or should I replace driver and passenger switches? Also, will any other Alfa model fit the gt? Any advice will be greatly appreciated.
Ben
Ben
