1 - 11 of 11 Posts
According to the advert they will.
According to the advert they won't - it doesn't mention the 2.0 at all. If you scroll down the page and it says:
BRAKELINE KIT WITH STAINLESS FITTINGS FOR:
ALFA ROMEO SPIDER & GTV 3.0 24v​
It is a bit ambiguous!
To the OP, if you want braided front brake hoses for the 2.0, I think Autodelta do them.
Perhaps a search for Goodridge hoses for ALFA ROMEO 145/146/155 or Fiat Coupe'
may help, they should be the same as the hoses for 2.0TS Spider.
Be careful not to get hoses that are to long; the braided ones that had been fitted to my car had worn dangerously because of this. If I remember correctly they were goodridge but I wouldn't know if they actually said they fitted my car or not so I wouldn't like to draw conclusions about the brand based on this.
There is an issue with the braided lines wearing dangerously around the 90 degree bend they take in the GTV/Spiders. Can be cured apparently by reinforcing the bend with some rubber tubing..
But I will tell you that is exactly the same place they wear out as standard. I had all my brake lines replaced last year and the fronts were badly, badly worn.
1 - 11 of 11 Posts
