Having recently r cleaned one faulty WCU and replaced another I now have a policy of disconnecting the Battery and giving it a while for the capacitors to drain before working.
Its overkill I know but I will explain what happened when I didn't do this.
It started with a door open reading from the drivers side when the door was closed...intermittent fault and a problem because if it happens while the car is parked it triggers the alarm. The window will also open as they are designed to when the door is opened.
Its not fun sorting this in your jim jams at 3am ! Alarm going off,wet seat..not good.
Sorted that night by perseverance and when the window finally went up disconnecting the battery and manually locking the car.
Next day...
I removed the drivers side window control unit and cleaned all conectors male and female ..checked it all over and re-connected.
However when I reconnected the WCU The fault was gone from the drivers side but had "moved" to the passenger side!
My mucker Barry used to work on PCB's for Phillips and mused that when disconnecting any part of a circuit power surges can happen and damage other components..especially PCB's which are very fragile...I did not on this occasion disconnect the battery.
After much faffing a replacement passenger side WCU solved the issue.
There were no codes registered at any point. It was simply a physical failure of the unit due to some strangeness occurring when fixing the drivers side.
All good now for a few months.
Proxy alignment is NOT required AFAIK.
Mine didn't require it.
DO disconnect the battery before messing with anything...
Good luck!
