I think it is very unlikely to affect the battery even though it does have one line direct from the battery, not through ignition. You could always disconnect the negative and reconnect in the morning,
These units go faulty eventually and that's why the odometer is flashing. Depends what you've lost and what you need!
If you want to check your battery condition see below.
1. Engine off.
12.66V . . . . . . . . . . 100%
12.45V . . . . . . . . . . 75%
12.24V . . . . . . . . . . 50%
12.06V . . . . . . . . . . 25%
11.89V . . . . . . . . . . 0%
2. Charging voltage with engine idling should be 13.5V to 14.5V
3. Ensure the engine cranking voltage is between 9.67V and 10.57V.
1. Engine off.
