1 - 20 of 23 Posts
Hi, I have Alfa 147 selespeed and yesterday I bought lancia kappa coupe 2.0 20v turbo 175A3000 to remove its engine and gearbox (very similar with Fiat coupe) and fit it in my alfa!
I want to know if someone has done it before?
The selespeed will be the problem as It has its own ecu which works with the ts engine ecu.
People have looked into this but I dont think anyone has managed it although I hope that you are the first :thumbs:
L
AFAIK he would have to use the Fiat gearbox, the fiat wiring looms etc, once he has the donor car in his yard he's ok.
In that case It would work with alot of extra work as you'd need to fit in a clutch pedal, slave cylinders, 147 manual gear stick just for starters.
A Coupe engine + Selespeed would be unreal :cool:
Hi, after about 4 months today we finish the car. We start it and it s working very good.
Tomorrow I will make some pictures.
how did you manage the body computer and Alfa's electrical units?
does the Alfa's dashboard work properly? does it show the fuel consumption?
thank you for any answer.
1 - 20 of 23 Posts
