I think it should be possible.
Have a look in the photo I have attached.
To me they look similar and the puddle light with p/n 51878127 is used in a lot of different cars from Fiat Group
If your car is a Ph1 the connector might be of a different type that don't fir the later puddle light lamps
The connector is the same as fitted to phase 2/3 cars ( phase 1 is different ).
159 part number is 51878127 which matches the phase 2 916. So it should fit.
A P1 can be converted to P2/3 connectors with 2 TE Multilock 070 2 way connectors ( about £1.20 each at Radio Spares ) and four TE 070 crimp terminals.
https://uk.rs-online.com/web/p/pcb-connector-housings/3628998/
https://uk.rs-online.com/web/p/pcb-connector-contacts/7122188/
Ideally a crimp tool is needed but it is possible with pliers and a soldering iron.
Or if you're in mid Beds anytime, drop in. It'll should only take me about 10 minutes.
It'd be interesting to see how well those lights work.
Peter... as always many thanks for your input; very much appreciated. Both mine are Phase 2 so hopefully it will be a straight swap.
Many thanks for the offer of assistance, very kind of you. I’m not sure I can afford a trip to Beds given the number of beers I owe you for all your help and advice over the years.
