1 - 18 of 18 Posts
Hey guys/Girls
Hoping someone has had a similar problem or is able to point me in the right direction.
I bought yesterday the Three MiFi device, I had to go back to the shop today as the WiFi was not connecting to my laptop or any other device, although it would connect using the cable.
I now have a new device and it's connected to my Wii fine no problems, Mobile is a little iffy but I do have a blackberry (not the best really) but still not connecting to my laptop unless it's with a cable.
The Error I get is that the PIN is not correct of Verified but its worked on the WII and it's the same code within the settings so it's defaintly the right code...
This is the same issue as yesterday, I called Three and there baffled. Now it must be my laptop but haven't got a clue where to start
Any ideas?
:thumbs:
Administrator
When you say the laptop is asking for a PIN, I wonder if you're trying to enter the wrong information?
What the Wii and probably the mobile require is the security passphrase or key. You can also use that with the computer - but the fact that it's said PIN suggests it is trying to use a different way to connect.
With some routers, you can also press a button on the router which enables a shorter and easier to remember PIN number.
All that said, I can't be much more helpful, as I can't remember the option when setting up. The only thing I can suggest is when tbhe laptop asks for the PIN, see if there's an option somewhere on the screen called something like "connect manually", or "connect using SSID". If there is, that should take you to the right screen to enter the network key you possess.
Yes it is a 8 digit WIFI key its asking for an thats what I'm putting in... I will try manually and see what it does.. If I can
Quite probably your laptop doesn't like the type of wireless security that the MiFi unit is using.
How old is your laptop?
Can you view the wifi connection on your mobile and see if it gives any info into the type of security, it'll be something like WEP, WPA, WPA-PSK etc
I don't know if the MiFi unit allows you to change the security type.
its all numbers so no problems with case sensitive...
unfortunately it won't let me into the settings to look at it. :(
The MiFi unit may have settings via 192.168.1.1 or is this where you've been checking? Is it asking for a username and password? There are usually defaults used if not changed (what brand is it?)
It does sound like the two devices aren't compatible in their security type though... Unless you can change the setting of one or both. What age is the laptop/make/OS?
Laptop is a Samsung R60 - Pentimum 2 processor, Windows Vista
The MiFi is a Three which are made by Huawei
Just asking for a KEY, I have tried to connect manually aswell and it connects but doesn't let me on the net. Very odd but could really do with fixing it... trying to batter the eye lashes with the IT staff here too.
C
A quick google shows that Vista can be a bit ropey with certain wireless security settings and not just with MiFi devices.
Do you know what type of security setting your laptop is using - look for something like WEP, WPA-PSK or WPA2-PSK.
I think AmicusPro has hit the nail on the head - you may have one type of security on your laptop and another on the MiFi. It should be possible to sort it out but you'll need to have the necessary access rights to amend the settings on your laptop.
a quick google shows that vista can be a bit ropey with certain wireless security settings and not just with mifi devices.
Do you know what type of security setting your laptop is using - look for something like wep, wpa-psk or wpa2-psk.
I think amicuspro has hit the nail on the head - you may have one type of security on your laptop and another on the mifi. It should be possible to sort it out but you'll need to have the necessary access rights to amend the settings on your laptop.
ahem. ;)
quite probably your laptop doesn't like the type of wireless security that the mifi unit is using.
Can you view the wifi connection on your mobile and see if it gives any info into the type of security, it'll be something like wep, wpa, wpa-psk etc
i don't know if the mifi unit allows you to change the security type.
Looking around on-line, it appears that the MiFi device (assuming the same model) doesn't support WEP so you need to connect via an alternative as suggested by others (WPA etc) or set it to "Open" (i.e. no security) which isn't the best option but sometimes the only one if the PC side isn't supporting anything apart from WEP (for example, the Nintendo DS only supports WEP I think). In theory, you can change the security connection type within Windows but I'm not a big user/fan of Vista as I still use XP for most home stuff... If you can get the equivalent of "Wireless Networks" tab on "Wireless Network Connection Properties" then select the MiFi device/network you're connecting to and look at its properties... You need to then look in the "Wireless Network Key" area for "Network Authentication" and make sure it is set to WPA if possible (you could try WPA2, WPA-PSK or WPA2-PSK). In fact WPA2 should be stronger than WPA etc. Then usually the Data encryption is set as TKIP but again, feel free to try AES if it's still not working - if in doubt, a bit of trial and error isn't going to kill anything.
Hope that's some help! Keep us posted and I'm sure someone will have inspiration as to how to fix it (or if someone can translate the above into clearer Vista instructions to try)... at least if it's not the above we can know its tested and eliminate if from the options.
As Bobda said though, if you can view the Network Authentication/Data Encryption details on your mobile it may help you get the right settings (i.e. get them to match each other).
Connect the MiFi to your laptop.
Wait for it to boot up and be recognised, you should then double click the icon on the desktop and this will start the "Homepage" of the device,.
MAKE SURE IT IS SHOWING DISCONNECTEDFROM THE NET, and then select the security settings tab. From here you can see the options and more importantly set a memorable password and change the Mifi SSID.
Then follow what Amicuspro said above regarding settings on your Laptop.
Good luck.
Discussion Starter #15
Once the Mifi is hooked up using the cable thats it, it's on the net so I can't get to the security settings :rant:
Word doc of what I can get into... I click the Icon it just goes to the Three home page and messages :|
1 - 18 of 18 Posts
