1 - 9 of 9 Posts
hi friends...!!!
I have a problem with my car, i can not find a place that have the replecement parts that i need, I already try EB spears but no body give me info...guys, do you know a place that have a very good numbers of parts for 1993 Q4?, I need the gasket set for the whole engine, also need both bearings in the distribution and the distribution belts the one that is doble sided with teeth and the single one, the water pump and the secondary cylinder for the clutch.
have to be one that ship woldwide...any info will be very appiciated.
happy motoring!!!!
Try sourcing a Spesso(?) uprated head gasket.
The other parts will probably be main dealer and need ordering as not many companies in the UK stock Q4 parts as there were no many cars imported here.
Your list will not be cheap!
wrinx
Dealers sell all these parts in the UK, but EB are the only ones who ship worldwide I think. I could enquire for you from here if it helps and get you a price.
So you need:
A full engine gasket set
Cam Belt
Balancer Belt (double sided)
2x Tensioners
Aux belt
Also get the power steering a air con belts, may as well change them
Water pump
Clutch slave cylinder
Any more? This is quite an expensive list
Is it not easier & cheaper to go via Lancia? Most of the parts will be the same surely?
1 - 9 of 9 Posts
