On the rare occasions I have the top up it creates a really annoying whistling from the drivers side - its coming from the top corner where the quarter-light frame meets the hood and is better if the window is wound down slightly (that creates a different sort of noise so isn't a solution) - seals are in good condition -
Anyone any idea what's causing it and got a good idea on how to stop it
Thanks Dom -so they can be adjusted, I'll have a look later - is it a difficult job?
Trim off - two 13 mm bolt heads but unfortunately mines already at the maximum height so I just fettled it to fit the window glass better - the hood seems quite tight against the frame so I guess its just a case of adding some discreet lumps of foam until it stops - the hood fits much better than any of the brit iron I used to drive anyway
Adjusted the hood clips to make them a bit tighter and that seems to have done the trick
