Hi All, hope you can help with the following.
I have a 55 plate 2006 Alfa GT JTD bought in 2010 with approx 85k.
The Clutch and (used) flywheel replaced at approx 120k @ autolusso
Now it's at 150k and noticed slipping on cold mornings in 1st.
In prep for the dreaded day, I decided to get the parts and found a Genuine new 3 piece clutch kit Part No: 71749477, which I bought as it said that it fit the 150bhp jtd GT.
Then started looking around for flywheels and noticed several different part numbers (confused.com).
ePer states the clutch kit should be 71739501
Alfa Workshop have the following for 1.9 jtd's:
71749477 for £156
71739501 for £303.58 (150bhp Only)
71752488 for £174 (Ducati 170bhp)
So my questions are:
Will all of the clutch kits fit or do I need the one stated on eper?
If the one I bought will fit, is it weaker than the 150bhp one?
What part number for the flywheel should I be looking for, do they need to match the clutch kit that is bought?
Finally, any advice on any other jobs that should be done whilst clutch is out would be appreciated.
Cheers in advance, Vik.
JTD 8v stage1+
GT 1.9 JTD 16v 150 Euro3 clutch kit 71739501 and flywheel 55190650 and 55193588 and 55212854 (latest)
GT 1.9 JTDm 150 Euro4 ck 71749477 and fw 55193588 and 55212854 (latest)
GT 1.9 JTDm 170 Euro4 ck 71752488 and fw same JTDm 150
In resume, crankcase and clutch bearing is the same for all and fw is compatible for all and ck is compatible, but JTDm 170 is reinforced ck. Your 71749477 must to work with you fw.
Thanks for that, now to find a cheap new Fw.
So is it possible to fit Ducati ck set on GT 1.9 JTD 16v 150 Euro3? Factory flywheel.
Interesting info, but I got confused. Thanks!
JTD 8v stage1+
Yes if fw is 55193588 or 55212854 (55190650 probably too but not checked). JTDm 170 ck is 9% stronger.
