1 - 11 of 11 Posts
I know this has probably been asked before but I am confused. I e-mailed the guys at shop4parts.co.uk and they have confused me even more.
Tutela CS Speed is the fluid for the hydraulics etc
The actual gearbox requires......?
The Selespeed system uses Selenia CS speed fluid (0.6L)
The gearbox uses 75W90 GL5 spec full synthetic gear oil. (2L)
As far as I know it just needs standard 75w90 gear oil (it's a manual gear box with actuators on rather than an auto) I believe it's Tutela ZC75 Synth.
David C will know, if he's out there.
Done a search as my oil level seems low.
This came up, but my manual says Tutela CS speed oil for the selespeed.
Is that something different?
Same thing.
Tutela is just one of Selenia's ranges.
As long as you are putting it in the tank next to the passenger wing thats selespeed oil, try a fiat garage they do selenia products as well.
afaik, Castrol Dexron III [ 3 ] is a direct replacement for Tutela CS, more available & cheaper than Tutela
I can supply it to Irish owners for €10 per litre
Have you or anyone else actually used this for your car? Does it work fine? Same as the Tutela oil??
1 - 11 of 11 Posts
